In spite of the digital quest, many sensors, especially in industrial applications still require analog outputs. So SICK’s newest MPA magnetic positioning sensor has both a 4 to 20 mA analog current output and an analog 0 and 10V voltage output. Measuring lengths from 107 to 1,007 mm, the sensors provide an alternative to potentiometers and other displacement sensors. The sensor has an IP 67-rated aluminum housing that can be mounted on various cylinders.
Typical applications include detecting piston movements in pneumatic cylinders and for positioning pneumatic drives used for feeding, gripping and measuring.
For more information about SICK MPA magnetic positioning sensor, click here.
Filed Under: Sensor Tips
