Magnetically coupled components have the following advantages over non magnetically coupled components: they are less expensive; they are made using less material, so they are more compact and weigh less; and their loss balances are lower. Faster clock frequencies are possible.
Depending on the application, magnetically coupled components, like those from SMP, are constructed for use as transducers, medium-frequency transformers, flux-compensating chokes or controlling chokes. Controlling chokes are produced by adding another coil in the role of transformer. They are implemented, for example, for control signals, for monitoring choke saturation, to measure current, to adjust the quality factor with thermal relief of the choke, also with possible energy recovery, and for setting a specific induction by premagnetizing the magnetic material.
The quality factor is set without exposing the choke to any thermal load, and EMC considerations are reduced. The magnetizing and leakage inductances can be specifically set by adjusting the magnetic coupling. You do this by varying the geometries of the injection molded parts and using different coil types, such as separately wound coils, bifilar coils or superimposed wound coils.
The range of magnetically coupled components is designed for currents up to 2,000 A and frequencies up to 500 kHz, which can be increased to 2 MHz in special applications. SMP uses powder composite materials that have been developed and manufactured in house and feature lower eddy current and magnetic reversal losses. The three-dimensional isotropy of the materials results in compact, lightweight structures because the magnetic circuits are minimized. This also lowers the magnetic field strength, and the quantity of winding material used can be significantly reduced. Special magnetorestriction-free materials ensure that components run quietly. These materials, which are developed and produced according to individual customer specifications, have a high saturation induction, up to 2 Tesla. And the oscillation behavior of the choke can be adjusted specifically by using certain materials or appropriate, magnetically coupled constructions with multiple coils.
Magnetically coupled components are used in industrial applications in power electronics; automation and signal processing; in drive units for railway engineering, electromobility, maritime and medical engineering; for renewable energies as well as for energy supply; and in the aerospace industry.
The components can be manufactured with dimensions ranging from 19 to 300 mm, weighing from 0.05 to 130 kg, and up to temperature class H (up to 180° C). Protection classes up to IP66 are available according to the intended application. All components are RoHS and REACH-compliant, the materials used are UL listed.
SMP has its own, UL-approved insulation system and in-house capability to issue UL certification up to 1,000 A; for currents higher than 1,000 A, certification is carried out externally.
SMP Sintermetalle Prometheus
smp.de
Filed Under: TECHNOLOGIES + PRODUCTS, Power supplies
