MakerBot, a global leader in 3D printing and subsidiary of Stratasys, announced the addition of Nylon to its growing portfolio of engineering-grade materials, bringing the total to eight for the METHOD platform. Optimized for high abrasion resistance, Nylon is widely used for functional prototyping and end-use applications within the automotive, industrial products, and consumer products industries.
Due to its high flexural, tensile, and impact strength, Nylon has strong mechanical properties and is ideal for applications that require repetitive motions or applied force, such as manufacturing tools and fixtures, articulated parts, snap fits, living hinges, gears, and air intakes. These parts often experience increased heat due to friction and may require flexibility due to interactions with other parts. Nylon also has high thermal properties and is heat resistant up to 180°C.
Nylon is sensitive to moisture and can easily absorb water in the air. This tendency can cause filament stored in even moderate humidity to produce parts with warping and deformation. METHOD’s sealed material bays can keep Nylon free of damaging humidity. A new spool drying feature will also allow customers to use the METHOD X heated chamber to dry out Nylon spools that have been affected by moisture uptake.
A suite of built-in sensors also helps to ensure materials are stored in their optimal environments—a feature previously only available in traditional industrial 3D printers. In addition, printing Nylon with MakerBot’s water-soluble PVA support material enables users to print complex geometries.
MakerBot is scheduled to premiere Nylon at FABTECH 2019 in Chicago, Illinois, at booth A3739 in South Hall.
Nylon is expected to begin shipping in early 2020 and will be available in black.
MakerBot
www.makerbot.com/3d-printers/materials/method
Filed Under: Uncategorized
