MakerBot, a global leader in 3D printing, expanded its materials offering with polyethylene terephthalate glycol, better known as PETG. PETG is the first Specialty Material to be released for the MakerBot METHOD 3D Printer.
“PETG is the first in a new line of materials for METHOD. Our customers have been asking for different materials to use for a range of applications that require high strength and durability,” said Nadav Goshen, CEO, MakerBot. “PETG is one of the most widely used polymers today. Because of its properties and versatility, we view PETG as an excellent material to be used on the manufacturing line and for short-run production runs.”
PETG can be used for parts such as functional prototypes, jigs and fixtures, and end-use parts. This industrial-grade material has a heat deflection temperature of up to 70°C and strong layer adhesion to reduce shrinkage and warping during printing. PETG is resistant to moisture and many chemicals, including some alkali and acidic substances. It can be used with METHOD’s water-soluble PVA for complex parts and effortless support removal.
PETG has greater strength and flexibility qualities than other materials, such as PLA and ABS, and is odorless when printing. Further, the material prints with a glossy finish and has a good degree of ductility.
METHOD Specialty Materials are intended for users looking for advanced material properties. They provide basic print performance and can require additional workflow steps to print successfully. PETG requires the application of an adhesion stick to the build plate prior to printing.
MakerBot also has a line of Precision Materials that are the primary materials developed for METHOD and cover the majority of use cases for prototyping, jigs and fixtures, and end-use parts. These materials have been extensively tested by MakerBot for the highest reliability and measurably accurate parts. These materials currently include MakerBot Tough, MakerBot PLA, and MakerBot PVA.
PETG is now available to purchase and expected to begin to ship to customers in late June.
MakerBot
www.makerbot.com/PETG
