Markforged’s new FX20 3D printer is targeted at point-of-need production of industrial-strength end use parts. This production-ready hardware prints the flame-retardant, high-performance thermoplastic ULTEM 9085, in filament form, in combination with Markforged’s propriety Continuous Fiber Reinforcement printing technology. This material meets the needs of demanding industries such as aerospace, defense, automotive, and oil & gas.
Built to scale distributed global production, the FX20 is precision-designed and sensor-driven for accuracy, quality, and reliability when fabricating parts at the point of need with the simple click of a button. As the biggest, fastest, and smartest 3D printer Markforged has ever produced, the FX20 pairs size and throughput to make larger parts fast. This technology, alongside high-temperature printing capabilities, elevates the Digital Forge platform from accessible industrial-strength composite manufacturing to robust production applications. The FX20 has a heated build chamber capable of maintaining up to a 200°C temperature and the capacity to print parts up to 525 mm x 400 mm x 400 mm in size. The FX20 is up to eight times faster than the default print settings on Markforged’s existing line of composite printers and prints nearly five times larger builds than its next largest printer, the X7.
Vestas Wind Systems A/S , a global leader in sustainable energy solutions, plans to use the FX20 with existing Markforged composite materials and the new ULTEM 9085 filament with continuous fiber reinforcement to print stronger, higher volume parts.
“The Digital Forge has given Vestas a powerful platform to circumvent expensive, multi-step, and time-consuming conventional manufacturing methodology,” said Jeremy Haight, Principal Engineer at Vestas. “When you factor in design iterations, these conventional parts are obsolete in a year or two. With the FX20 and ULTEM 9085, we will be able to design and manufacture larger, stronger parts, press a button and take that part right off the print bed to use it immediately with the confidence that it is very durable and robust.”
The FX20 and ULTEM 9085 filament are expected to ship worldwide in the first half of 2022. FormNext attendees can see the printer at Markforged’s booth, 12.0 D01, from November 16-19.
Markforged
www.markforged.com
Filed Under: Make Parts Fast
