    • Subscribe!
Mars Labs Supports Aerospace Static and Dynamic Load Testing for Design Validation
By Test and Measurement Editor | December 19, 2013
Mars Labs, LLC, a global manufacturer of rugged, high-performance data acquisition for aerospace, automotive, off-road , military, and test and measurement applications, has introduced the Titan™ CPU Expander for its modular DAQ system for use in larger-channel-count commercial and military aircraft design validation and durability testing.
In static strength testing for aircraft wings and airframes, data must be acquired on the aerospace structural response to applied loads. This type of testing is commonly used to simulate the loads applied by large transient forces such as wind shear, which can have significant mechanical effects on aircraft performance and mechanical integrity. Depending on the size of the structure undergoing testing, the DAQ channel count requirements can range anywhere from a few hundred up to a few thousand. The data are used to compare the empirically derived and simulated mechanical response of the structure under test and thus verify its design integrity. In addition to static strength testing, the structures are also subjected to cyclic loading to replicate vibrations experienced during normal operation. The resultant high volumes of synchronized data, collected as the structure reacts to applied loads and vibrations, are then analyzed to assess aircraft wing or airframe strength and durability under such conditions. Because of the large number of DAQ channels involved in testing, a high-channel-count, large distributed DAQ system is required to obtain dynamic frequency measurements, which range from static, or steady state, to frequency bandwidths of up to 50 Hz.
The modular Titan™ DAQ from Mars Labs, available in both standard and custom models, can be used for durability and fatigue, noise and vibration, shock, compression and acoustics measurements. It is expressly designed for direct integration with a wide range of sensing types, including IEPE-type piezoelectric (ICP, Piezotron, ISOTRON and others) accelerometers and microphones; full active bridge MEMS-based piezoresistive accelerometers; and quarter-, half-, and full-bridge strain gage transducers. The Titan™ Mini-Recorder features 16 channels of low-drift, low-noise analog front end with excellent stability for longer duration dynamic test requirements. Additional features for aerospace wing and structural loading testing include 8-pole Butterworth filters and an improved 10-pole linear-phase filter; channel-count expandability; and analog output support.
Each compact Titan CPU supports up to 8 Titan Mini-Recorders, providing communications, synchronization, and data storage for the attached devices and enabling the creation of DAQ systems with up to 128 analog channels plus digital channels. To address the application’s need for higher channel counts to acquire sufficient structural performance data, the Titan CPU Expander connects multiple Titan CPUs together to create DAQ systems with up to 1024 analog channels plus digital channels, with data recorded directly to an internal 16 GB SD card (with support for 32 GB) or to a host PC. The connection of Titan units via the CPU Expander allows for significantly increased channel counts, meeting the high-channel count requirements of many aerospace related applications. Sampling rates are up to 2500 samples/s and the system also features auto start/auto record as well as a cabled remote control for remote start/stop of recording. The compact, low-weight, rugged system provides power, communication and synchronization via Ethernet cable.
Based in Laurel, Maryland, USA, Mars Labs is an innovative engineering-driven company whose products are utilized primarily for military and commercial vehicle testing, mechanical simulation, rail and mass transit system testing, process control and feedback, structural monitoring, remote vehicle monitoring, and in-laboratory university R&D.
Mars Labs
www.marslabs.com
The post Mars Labs Supports Aerospace Static and Dynamic Load Testing for Design Validation appeared first on Test & Measurement Tips.
Tagged With: marslabs
eBay
When to buy used test equipment
TRACO Power now sells cost-optimized 1-A POL converters with 6-to-36-V input range
eye diagram
Simpler debugging for Automotive Ethernet systems
E+H-Prosonic-flowmeter
Flowmeter for industrial water, feedwater, cooling water and condensate
    • Subscribe!
