Marsh Bellofram Introduces New Solid-on LED Universal Power Alert
By Dave Miyares | January 6, 2011
The Diversified Electronics division of Marsh Bellofram Corporation has announced the global market introduction of the UPA-130S series. This newest addition to the Marsh Bellofram UPA-130 series, the “S” model, is designed to provide solid-on LED lighting and alert capabilities for those monitoring applications requiring enhanced NFPA70E and OSHA safety compliance, instead of the flashing LED’s found on the standard model.
MarshBellofram_UPA_130S
The UPA-130S series is designed to reduce the risk of electric arc flash by pre-verifying the electrical isolation from outside of a control panel before its re-verification with a meter. The series operates over a standard range of 40 to 750 VAC (30 to 1000 VDC) line-to-line or ground-to-ground, is phase insensitive and offers high surge immunity protection. When hardwired to the load side of a circuit breaker or main disconnects, the UPA-130S series detects stored hazardous AC and DC voltage in any individual phase. After disconnecting power to an enclosure, electricians can pre-verify voltage isolation while an enclosure door is still safely closed. The compact, UPA-130S series offers a potted construction with six-foot leads and is designed to fit a 30mm knockout. Its design includes redundant circuitry and the incorporation of long-life display panel LEDs for extended use, with components housed in NEMA 4X, 12 and 13 electrical enclosures.
The UPA-130S series is a reliable safety tool for pre-verification of the presence or absence of residual electrical power or charges, or as a zero energy indicator, both before or during mechanical lock out/tag out (LOTO) procedures. It is particularly ideal for use in government project applications, which are typically characterized by more stringent requirements for solid LED lighting, to avoid triggering certain medical conditions that can result from visual exposure to rapidly flashing lights. The UPA-130S series is also ideal for use in applications such as circuit breaker disconnects, as well as with NFPA 70e Category III and IV high energy panels; or as an added electrical safety tool on other types of frequently accessed electrical panels. In addition to its hazardous area certifications, the UPA-130 is also compliant to CATIII and CATIV standards, and is CE marked and UL-approved in both the US and Canada.
Marsh Bellofram
www.marshbellofram.com
Filed Under: Electronics • electrical, Lights • signal lamps • indicators, Power supplies, Safety systems + components, Test + measurement • test equipment
molex-premo-flex
