    • On the Floor
Maximum torque in minimum space with maxon Spiroid gears
By Lisa Eitel | July 7, 2015
Maxon Spiroid Gearheadmaxon precision motors introduces right angle gearheads designed to be configured with maxon’s 22 and 32 mm DC motors.  These compact, lightweight and high torque gearheads were developed to transmit power at 90° in the smallest possible form factor. The Spiroid technology incorporated in the gearhead design offers a number of performance benefits:
  • Extremely high torque transmission
  • High stiffness / Low deflection with large applied loads
  • Back-drivable (4:1 ratio) and non-back drivable (31:1 ratio) versions
  • Compact size
  • Low backlash
  • Up to 3:1 “gear teeth” contact ratio
  • Quiet operation
  • High Torque to Space Ratio (HTSR) technology
The gearheads may be mounted directly onto many of maxon’s brushed and brushless motors or they can be configured with different ratios of maxon’s GP22 and GP32 planetary gearheads. This results in a wide range of achievable gear reductions. The motor and gearhead combinations are ideally suited for a variety of applications particularly where an output shaft perpendicular to the motor axis is desired.
www.maxonmotorusa.com
Motion Control Tips
Tagged With: maxon
Lisa Eitel
  • Industrial automation accelerates with increased capital spending
    • On the Floor
