maxon motor has developed a sensorless speed and torque control solution called High-Performance Sensorless Control (HPSC). This new technology allows FOC (field oriented control) for brushless motors without sensors from full stop to full speed under load.
[Related: maxon motor introduces exoskeleton joint actuator]
The maxon motor HPSC uses a sophisticated signal injection algorithm which precisely determines the rotor position for a smooth startup each and every time.
– Low noise, no vibrations
– Maximum power efficiency
– Robust and reliable
The maxon motor HPSC contains an HPSC module 24/5 — dimension and power range can be adapted if required. The firmware of the module may be customized for every drive system. HPSC is a custom-made solution ideal for surgical systems, fluid-delivery systems, and rehabilitation and prosthetics.
For more information about the, contact maxon motor at [email protected].
Filed Under: The Robot Report
