Mead Introduces New Isonic® Valve
By Patrick Curran | July 14, 2009
Chicago, IL – Mead Fluid Dynamics announces the arrival of the newest addition to the patented Isonic® valve line, the V2 series. The new V2 is a 2-and 3-way solenoid-operated, direct-acting pneumatic valve. With flow in the range of 0.01 to 0.05 Cv, the V2 is available with multiple voltage and electrical connection options in both normally-closed and normally-open styles.
At the heart of the V2 is the award-winning Isonic® design, which enables flow channels to be molded directly into polymer body sections. This eliminates the abrupt air path changes associated with cross-drilled machining in traditional valves. The resultant ribbon-like flow paths create near laminar flow with little energy/pressure drop through the valve. Built-in, push-to-connect collets allow for simple tube and manifold connections in seconds.
To view the V2 valve system in action, including “how it works,” and the snap-on/quick-release manifold, visit bimba.com/MeadV2.
Bimba Manufacturing
www.bimba.com
Filed Under: Fluid power, Pneumatic equipment + components, Valves
5 ways to improve packaging machinery with smart pneumatics
Clippard-Cordis-CFC-electronic-Flow-Controller
Cordis flow controller offers high resolution and repeatability in a closed-loop system
Upgrading equipment with solenoids
Clippard Eclipse proportional Valve
Proportional isolation valve offers ultra fine resolution and high repeatability
Going small with 3D printing
