For high-speed distance and position measuring, the FADK 14 Pulsed Red LED Sensor has resolutions of 0.1 mm to 1 mm at a sensing range of 50 to 400 mm. The Sensors deliver accurate measurements regardless of the substrate material or the color of the target object, and measurement accuracy is not affected by strong ambient light up to 25 kLux.
The sensors have a transparent rear housing that allows operating and reception LEDs to be viewed from practically any angle, simplifying installation and operation. These sensors are available in current or voltage output versions and feature an integrated alarm output.
Baumer Ltd.
www.baumerelectric.com/usa
Filed Under: Sensors (position + other), Test + measurement • test equipment, Vision • machine vision • cameras + lenses • frame grabbers • optical filters
