The ternary® actuator is an all-in-one linear actuator system that merges mechanics with intelligence – integrating controller, motor, amplifier and drive into one compact mechatronic device. For rotary motion, the basic ternary® device can be used alone or paired with an alpha gearbox. For linear requirements, a ballscrew or slider is added to the device. Setting parameters for functions is easy with the included programming software. Depending on the type of operation, you can also write a program that contains specific positions and motion profiles. With low voltage requirements, a variety of control interfaces and no maintenance, the all-in-one system fits new applications as well as for retrofits and upgrades for pneumatics.
WITTENSTEIN
www.wittenstein-us.com
Filed Under: Factory automation, Actuators, LINEAR MOTION, Motion control • motor controls, Mechatronics
