Medium and High Pressure Products Guide from IPT
By Miles Budimir | June 2, 2009
ERIE, PA — Innovative Pressure Technologies (IPT) introduces a new Medium and High Pressure Products Guide. This brochure provides an overview of IPT’s family of medium and high pressure valves, fittings and tubing, as well as custom solutions and specialty products, including key features and specifications. Medium pressure products are up to 20,000 PSI, and high pressure products are up to 60,000 PSI.
Medium and high pressure products that are reviewed include needle valves, ball valves, check valves, double block and bleed valves, 2-, 3- and 5-way manifold valves, as well as fittings and adapters. Custom solutions and specialty products that are reviewed include banjo fittings, monel drip pots, fusible plugs, manifolds, fittings, double block and bleed valves, relief valves, ball valves and excess flow valves.
www.inpressure.com
Filed Under: Tubing components, Valves, FLUID POWER
Miles Budimir
