Meggitt Sensing Systems, a Meggitt group division for sensing and monitoring systems for extreme environments, has announced an extension of its family of Endevco brand Isotron accelerometers. This new line of general purpose IEPE accelerometers meets the needs of a wide range of test applications.
The Endevco brand embodies decades of sensor design and application expertise. That legacy, combined with Meggitts global capabilities, has resulted in general purpose accelerometers of the highest quality plus low cost and availability needed by todays test professionals.
Applications include general laboratory vibration testing, automotive testing (NVH, component reliability), universities, aerospace component reliability, vibration testing/monitoring of large equipment (industrial/manufacturing equipment), energy, rotating equipment, turbines (gas, wind, steam), defense, consumer electronics, household products and shaker table vibration feedback.
Endevco models 41A, 42A, and 43A are general purpose, single-axis accelerometers. 10, 25, 100, 500 and 1000 mV/g sensitivities are available for the 41A and 42A, with 100, 500 and 1000 mV/g for the 43A. Amplitude response of ±5% is 1 to 10000 Hz. These stud-mounted accelerometers have a 10-32 threaded hole, and the customer may specify a 10-32 stud, 10-32 to 28 stud, 10-32 to M6 stud, or 10-32 to M5 stud.
Model 41A mounting bottom is a hex with 10-32 top connector. Model 42A mounting bottom is hex with 10-32 side connector. Model 43A has unique cube shape which allows mounting in two different orientations, with the sensitive axis parallel to the connector and 10-32 connector. Optional accessories include cables, an adhesive mounting adapter and signal conditioners.
The Endevco model 45A is a general purpose, high sensitivity, triaxial accelerometer in a 20-mm cube shape with 500 mV/g (10 g range) and 1,000 mV/g (5 g range) options. Amplitude response of ±5% is 1 to 6,000 Hz for y and z-axes, 1 to 3,000 Hz for x-axis. They are also stud-mounted with a 10-32 threaded hole and customer specification of a 10-32 stud, 10-32 to 28 stud, 10-32 to M6 stud, or 10-32 to M5 stud. Optional accessories include cables, an adhesive mounting adapter, isolated mounting adapters and signal conditioners.
In addition to existing cables, the new Endevco model C general purpose cable assemblies allow for user-selectable cable configurations. They are specifically designed for use with single-axis and triaxial accelerometers, as well as other transducers. Users can specify the sensor side connector, cable type, instrumentation side connector and overall cable assembly length in inches.
Endevco
www.endevco.com/general-purpose
www.meggittsensingsystems.com.
Filed Under: Green engineering • renewable energy • sustainability
