The Filtration and Separation Division of Parker Hannifin offers a complete line of Balston membrane air dryers specifically for use with Coordinate Measurement Machines (CMM).
Proven to be the best performing dryers for the most sensitive applications, Balston CM Series Membrane Air Dryers offer lower operating costs and better performance than both non-cycling and cycling refrigerant air dryers and eliminate downtime and costly repairs resulting from dirty, wet compressed air supplies.
Balston Membrane Air Dryers for CMMs offer a guaranteed dewpoint of 35° F and will remove compressed air contaminants down to 0.01 micron in size. Unsurpassed in performance and durability to dehydrate and purify compressed air, the Balston CM Series Membrane Air Dryers significantly outperform refrigerant air dryers in dewpoint reduction and are typically less expensive to operate.
The Balston CM Series Air Dryers are shipped complete to with prefilters, auto drains and membrane modules assembled for easy installation. The membrane module can be installed horizontally or vertically.
Parker Hanifin Corp., Filtration and Separation Div.
www.balstonfilters.com
Filed Under: Factory automation, Packaging, Fluid power, Pneumatic equipment + components
