Design:
* Both clamping hubs are completely separable, due to split hubs and two radial screws ISO 4762 on each hub.
* Any imbalance of the clamping hubs is compensated for by balancing bores located on the inside of the hub.
Temperature range: -30° C to +100° C (-22° F to +212° F)
Backlash: Absolutely backlash-free due to frictional clamp connection.
Service life: These couplings are maintenance-free if the technical ratings are not exceeded.
Tolerance: On the hub/shaft connection 0.01 to 0.05 mm
Material:
*Bellows made of highly flexible high-grade
stainless steel.
*Hub material see table
Brief overloads: Acceptable up to 1.5 times the value specified.
Speeds: Up to 10,000 rpm, in excess of 10,000 available with a finely balanced version.
Non-standard application: Custom designs with varied tolerances, keyways, non-standard material, bellows, and ATEX designs are available upon request.
Properties of Bellows Coupling model BKH:
* Easy to mount
* Suited for space-restricted installations
* Low moment of inertia
R+W America
www.rw-america.com
Filed Under: Coupling Tips
