METROLOGY INSTRUMENT ASSURES HIGH ACCURACY WITH LOW NOISE
By Natasha Townsend | July 23, 2012
By performing three precision measurements on one instrument, the Talyrond 500 Series offers an ultra-low gauge resolution of 0.3 nm assuring sufficient integrity for the most critical applications in a wide range of industries including aerospace, automotive and medical. Any cylindrical or round parts can be measured with high accuracy, including precision bearings, spindles, fuel injectors, crankshafts and turbochargers. Rotary, vertical and horizontal datums exceed the precision of the machine tool’s movement, allowing the instrument to exactly reproduce the work piece shape. Use of traceable standards and exclusive algorithms effectively eliminates instrument influence from the measurement results. Measurements can be exported to statistical process control systems that maximize production efficiency and reduce maintenance costs.
This series instruments do more than detect out-of-specification parts, it uses multiple analysis methods, which can identify location and cause of imperfections. A unique calibration routine allows correction for stylus motion and tip correction. This calibration allows measurement of angle, radius and form with respect to the part axis. Calibration, center and level functions and measuring routines are all performed automatically. Simplified teach and learn programming, comprehensive user prompts and on-screen instructions support error-free performance regardless of operator skill.
All axes of the 500 series are controlled for waviness, straightness and noise, whether using the spindle, column or arm. The frictionless air bearing spindle and precision column assure high accuracy roundness, cylindricity and straightness measurements, resulting in higher efficiency and reduced scrap.
Taylor Hobson
www.taylor-hobson.com
Test & Measurement Tips
Filed Under: Test & Measurement Tips, Bearings
Tagged With: Taylor Hobson
eBay
When to buy used test equipment
TRACO Power now sells cost-optimized 1-A POL converters with 6-to-36-V input range
eye diagram
Simpler debugging for Automotive Ethernet systems
E+H-Prosonic-flowmeter
Flowmeter for industrial water, feedwater, cooling water and condensate
