Molex, Lisle, Ill., has released the Micro-Lock Plus wire-to-board connector system for customers seeking high performance, compact size and retention security. Featuring a 1.5 A current rating, small footprint and positive latch, the company has reportedly developed a comprehensive terminal solution for OEMs working in space-constrained environments.
Designed for industries such as automotive, consumer, and industrial automation, the Micro-Lock Plus is suitable for a variety of applications, including vehicle switches, robotics, drones, home appliances and power tools.
Offered with 2 to 42 circuits, single and dual rows, and vertical and horizontal plug configurations, the product was designed for flexibility. It is one of a few 1.25-mm-pitch compact connector systems rated at a 105˚ C operating temperature and 1.5 A current rating suitable for use in general market applications. Connectors are offered in a variety of colors to aid assembly via color coding.
To ensure connectors are fully mated and avoid end-product failure in applications subject to shock, vibration and rough handling, the Micro-Lock Plus connector features a wide positive latch that delivers an audible click, providing assemblers added peace of mind.
“Oftentimes, designers have to forgo a positive lock on a connector due to space constraints, sacrificing retention security,” said Kazuhiko Ishikawa, global product manager, Molex. “Molex Micro-Lock Plus connector system is the smallest connector currently on the market with a positive lock, so engineers no longer have to choose between compactness and retention security.”
Secure contact and terminal retention are also achieved via the robust metal solder tabs and a dual-contact terminal design. Tin-bismuth terminals provide a clean and uninterrupted signal without the whiskering associated with tin plating and added cost of gold plating.
Molex
www.molex.com
Filed Under: Cables + cable management, Appliance engineering + home automation, Connectors (electrical) • crimp technologies
