    • On the Floor
Micro-machined Silicon Pressure Transducers
By Design World Staff | March 23, 2009
Omegadyne announces the most durable version of its high accuracy MM Series micro-machined silicon pressure transducers. The new hermetically sealed version of the MM Series features all welded Stainless Steel construction, 316 wetted parts and glass to metal seals (GMS) at the electrical outlets. This ensures that the unit is hermetically sealed from external environments and the media. Designed for use on automotive and aircraft test platforms and anywhere environmental concerns demand the most durable characteristics.
The sealed MMA500V Series has a micro machined silicon core that provides high accuracy, low drift and excellent long term stability in the harshest environments. Ranges from 100 psi to 5000 psi, accuracies from 0.08% to 0.03% and a variety of pressure and electrical connections make this MMA500V Series Transducer extremely versatile. The temperature compensation range can be as broad as -40 to 200*F (-40 to 104*C) and thermal errors as low as +/- 0.3% over the compensated range. Operating temperature range is -49 to 250*C (-45 to 121*C). The MMA500V Series design is further ruggedized with a secondary containment system in the event of diaphragm rupture. A 5-Point NIST traceable calibration certificate included.
The MM Series pressure transducers offer “Custom Designed” features with fast delivery. Our modular design allows you to construct a pressure sensor to meet your application requirements, with guaranteed fast delivery… typically from stock to 2 weeks. Our product configurator found online at omegadyne.com allows quick and easy configuration of a transducer that meets the exact needs of your project.
www.omegadyne.com
Filed Under: Sensors (pressure), Automotive, TEST & MEASUREMENT
  • Robot blowback in Korea and China growth slows
  • Robot safety in focus as regulations change
    • On the Floor
