Midwest Motion Products, Inc. has announced MMP S22-346F-24V GP52-014, a brushed 24V DC gearmotor capable of producing up to 38 in-lbs continuous torque and 142 in-lbs peak torque with an output speed of 296 RPM.
Description:
- Brushed 24V DC gearmotor capable of producing up to 38 in-lbs continuous torque and 142 in-lbs peak torque with an output speed of 296 RPM.
- IP54 protected, under 2.5” diameter, under 7.0” total length and weight is 3.8 lbs.
- Download your datasheet.
- Encoder-compatible, brake-compatible or both rear shaft designs available.
- Samples readily available – can be built from stock materials, usually within just a day or two.
- Short production lead-times – measured in weeks, not months.
For more information, visit midwestmotion.com.
You may also like:
Filed Under: Motors (gearmotors)
