Miki Pulley Introduces The BXR Spring Applied Brake To The US Market
By Frank Tobe | March 31, 2014
Miki Pulley is introducing their BXR Spring Applied Brakes for direct sale to OEM’s in North America.
The BXR safety brake may serve as an emergency brake, as well as a holding brake. Its unique, low profile design is 2/3 the thickness of other brakes in our lineup. In addition to saving space, weight is also dramatically reduced.
Miki-Pulley
The BXR is an ideal safety brake for robotic arms. In these applications, when a catastrophic power failure occurs, robotic arm movement must be halted immediately to prevent mechanical system collapse and equipment damage. In the event of power failure using the BXR safety brake, compression springs engage and capture the brake’s rotor hub immediately stopping arm movement.
Designed with a very thin profile, the BXR saves space in articulating joints. Idling wear is also reduced significantly because of its lightweight construction.
The BXR brake may also be installed on the output face of a servo motor, serving as a power-off holding brake. This can be an advantage when the overall assembly size must be contained in a small envelope.
Additional design benefits include a single friction plate, which provides fast response in high cycle applications. Armature engagement is smooth, quiet, and operates with no chatter. The BXR may function dually as an emergency brake and a holding brake.
BXR operating specifications are:
  • Brake torque: 3.688 ft. lb. – 40.566 ft. lb. (5Nm – 55Nm)
  • Brake outer diameter: 3.287 in. – 7.280 in. (83.5mm – 185mm)
  • Ambient Temperature: 14°F – 104°F (-10 ℃ – 40℃)
Miki Pulley
www.mikipulley-us.com
Filed Under: TECHNOLOGIES + PRODUCTS, Brakes • clutches, Mechanical
Tagged With: mikipulley
PROSTEP expands cooperation with Siemens Digital Industries Software
DRP - Line
Andantex will introduce a new planetary reducer design concept at IMTS
Custom pneumatic conveyors for unique applications
Advantech-iDAQ-3
Advantech launches iDAQ modular DAQ
