    • Subscribe!
Miki Pulley Micro Brakes for small, precise equipment applications
By Mike Santora | August 26, 2021
8648-Miki-Pulley-Electric-Micro-BrakesFast braking response in small, precision torque applications is the primary benefit of Miki Pulley Micro Brakes. Where high-performance braking for small motion control applications is required, these Micro Brakes provide the solution.
Miki Pulley’s ultra-compact brake design features a stator with integrated mounting flange, proprietary composite friction liner, and armature complete with ring plate spring and hub. Field-proven, these Miki Pulley Micro Brakes halt rotation mechanically by utilizing an electro-magnetic field to connect friction surfaces, thus creating mechanical resistance. With a fast response, the brake’s armature engages the stator when the coil is energized. A constant-force plate spring transfers torque to the rotating brake body halting all motion.
Additional features include quiet operation, high holding torque for its size, space-saving design configuration, long service life, stable and reliable braking power. Easily installed, these Miki Pulley Micro Brakes require no maintenance. They are available in three armature assembly options depending on application requirements.
Typical applications include ATMs, office copiers, weighing and packaging equipment, optical mechanisms, paper binding mechanisms and many others.
112 Model Micro Brake specification range based on model selected:
• Brake torque: 0.295 ft-lb – 1.770 f- lb (0.4Nm-2.4Nm)
• Backlash: Zero
• Ambient Temperature: 14 ~ 104 F; (-10 ~ 40 ℃)
Miki Pulley
www.mikipulley-us.com
Filed Under: Brakes • clutches
Tagged With: mikipulley
MagnaShear motor brakes make frequent start/stop cycles on cranes & conveyors maintenance-free
DELLNER BUBENZER debuts innovative and optimal performing disc brake series
MagnaShear motor brakes provide secure, no-maintenance holding brake solution for conveyors
Three torque-limiter options compared (and trip torque explained)
    • Subscribe!
