Mill-Max Introduces Highly Reliable, Precision-Machined Double Row SMT Sockets Packaged on Tape and Reel
By WDD Staff | September 24, 2013
The new 406 series SMT socket strip from Mill-Max is ideal for socketing leaded IC devices on SMT boards and for low profile board stacking applications.
The connector:
  • Is dual row
  • Has .100” (2,54 mm) pitch.
  • Accepts standard IC leads.
  • Provides a reliable interconnect solution when used in combination with SMT or through-hole headers.
  • Offers a low-profile height of 0.146” from the board surface.
  • Provides a board-to-board height of 0.300” when mated with a Mill-Max 429 Series SMT header.
  • Features four-finger contacts inside each precision-machined receptacle body to establish and maintain secure mating.
  • Features pin base of only 0.029” in diameter, allowing for a small PCB pad size and more space for routing traces.
  • Achieves a co-planarity of 0.005” for up to 20 positions.
  • Offers standard designs in 4- to 20-position configurations.
  • Is manufactured with high-temperature insulators.
  • Is compatible with all SMT soldering techniques, including RoHS-compliant environments.
  • Is packaged 335 pieces per 13” reel and fitted with a vacuum pick-up cap for enhanced accuracy and efficiency during pick-and-place assembly manufacturing.
For more information please visit www.mill-max.com/PR642.
Machine Learning for Sensors
