Mill-Max Offers USB 3.1 Type C Vertical SMT Receptacle
By Frank Tobe | October 20, 2016
Mill-Max has added the Vertical SMT SuperSpeed Universal Serial Bus 3.1, Type C to its line of USB IO Sockets.  This receptacle is 2X faster than USB 3.0 with more efficient data transfer, higher through-put and improved I/O power efficiency. Mill-Max already carries the USB 3.1 Top Mount and Mid-Mount style receptacles.
mill-max-usb-31-type-cFeatures:
  • USB 3.1 Vertical Surface Mount
  • Full metal housing with enhanced EMI/RFI prevention
  • Reversible USB Type C Connector.  The type C connector style has no polarization so cables, with type C plugs, may be connected regardless of orientation.
  • 2X faster than USB 3.0 (up to 10 Gbps) with more efficient data transfer, higher through-put and improved I/O power efficiency.
  • Maintains backward compatibility with previous USB versions
  • Provides optimized power efficiency to reduce drain on portable device batteries.
  • For Storage, Smartphone, Tablet, Notebook, Docking, Automotive and Home Entertainment
  • Packaged in Trays: 100 pieces per tray
Mill-Max also carries USB SMT and through-hole, Types A and B, compatible with USB 1.0 and 2.0 specifications; USB 3.0 through-hole mount sockets, Types A and B receptacles; USB 3.0 Micro-B SMT Sockets, Type B Receptacles and Mini USB SMT Sockets, Types A and B.
Mill-Max
www.mill-max.com
Tagged With: millmax
igus becomes world’s first manufacturer to receive UL approval for halogen-free TPE cables
igus expands E4.1 e-chain modular system for long travels
zuken
Harness-building software simplifies quoting process, automates harness documentation
icotek introduces CCL clamps
Going small with 3D printing
