Fischer UltiMate series from Fischer Connectors, St.-Prex, Switzerland, has been expanded to include the size 07, which is smaller, more compact and lighter than the current range in the Fischer UltiMate Series. It offers the same performance as the other sizes in the product line and is suitable for harsh and extreme environments.
With a diameter of 14 mm, the Fischer UltiMate Series 07 is available in a 2 to 9 contact configuration. This allows designers to create smaller devices with more connections and more functions with the same performance.
‘The Fischer UltiMate 07 is the answer to the users’ need for a smaller but rugged connector’, states Dominique Glauser, CEO of Fischer Connectors Group. ‘This new extension makes the Fischer UltiMate™ Series complete, as there is a much wider choice now both in sizes and pin configurations.’
The Fischer UltiMate Series is sealed IP68/69 mated and unmated and has a high corrosion resistance of 1000 hours. Combined with the 360° EMC shielding, the guaranteed 10,000 mating cycles and an operating temperature from –55°C to 135°C, it requires less maintenance, is cost effective and slow aging.
The Fischer UltiMate Series is now available in five sizes (07, 08, 11, 13 and 18) and in configurations from 2 to 42 pins. Cable assembly solutions are available in both straight and right angle overmolding. For ultimate protection of unmated connectors in the field, soft caps and bend relief are available for all sizes, including a wide range of tools and accessories.
Fischer Connectors
www.fischerconnectors.com
The post Miniature circular connector for harsh environments appeared first on Connector Tips.
Filed Under: Connectors (electrical) • crimp technologies, Connector Tips
