Miniature Servo Class couplings handle high speed reversing loads, and meet precise positioning requirements. The 16 mm diameter size Servo Class coupling has operating torque of 4.43 in.-lb in both single (SD) and double disc (SC) models. They suit applications that need high torsional stiffness and low inertia. The SD005 model delivers 43.3 torsional stiffness and 0.0009 in.lb2 moment of inertia. The SC005 model delivers 30.5 torsional stiffness and 0.0013 in.lb2 moment of inertia. All Servo Class couplings have zero-backlash, flexible metal stainless steel discs, and keyless clamp-style mounting hubs. Their robust design is maintenance free and they are easy to install.
Zero-Max
www.zero-max.com
Filed Under: Couplings, Mechanical, Motion control • motor controls
