Miniature linear guides for mounting in tight spaces
By Miles Budimir | March 24, 2022
IKO has expanded its LWL family of miniature guides with the addition of its newest LWLF2 linear motion rolling guide, which addresses the demand for device miniaturization with a compact, lightweight design that makes mounting easy in tight spaces.
The new LWLF2 features the same ultra-small 2.5-mm height dimension as its predecessor, the LWL1. It’s also designed with tapped rails for bottom mounting and stability. As part of IKO’s LWL family of miniature rolling motion guides, the LWLF2 guide is structured with two rows of balls that make contact with the raceway at four points to provide high stability and accuracy — even in applications with varying load direction or complexity.
linear guides
Additional features of the LWLF2 include:
  • Compact size – in addition to its 2.5-mm sectional height, the LWLF2 has a track rail width of 2 mm and slide unit width of 5 mm
  • Corrosion resistance – stainless steel construction is standard, making the new guides desirable in wet environments and applications where rust prevention oil cannot be used, such as in a cleanroom environment
  • Light weight – the LWLF2’s rail weighs 2 grams per 100 mm of length, and the slide unit weighs 0.21 grams
IKO’s LWL family of miniature linear motion rolling guides is appropriate for robotics and grippers, semiconductor fabrication, life science and aerospace applications.
For more information, visit www.ikont.com.
Tagged With: iko
Machining Center Manufacturing MCM S.P.A. to exhibit at this year’s IMTS
New size 17 hybrid linear actuator features enhanced performance
High-precision three-axis positioning stages feature four motor options
Programmable linear actuator features stroke to 100 mm
