Hoffmann + Krippner, Inc. now provides extremely slim, inductive displacement Inelta IZAL series sensors. Utilizing differential sensing technology, these innovative sensors ensure precise path length measurements in applications with highly confined spaces. Although the 4mm diameter housing of these Linear Variable Differential Transformer (LVDT) sensors are barely larger than a matchstick, their interior provides a complete and powerful differential transformer measuring system with a core and coils.
The contactless, wear-free sensors for displacement and position detection achieve a linearity tolerance of ± 0.5% (optionally 0.25%) and are designed for the extremely small measuring ranges of 1, 2.5 and 5 mm.
With a housing made of chemically nickel-plated steel (protection class IP65) and a temperature range of -25 to +85° C, (which can be extended even further upon request), these new miniature displacement and position sensors are suitable for use in harsh and demanding environments.
The actuation takes place via an unguided core, with the sensors being connected via a 1mm cable (optionally available in other lengths). Upon request, Hoffmann + Krippner also provides custom sensor versions with additional equipment options, e.g. individual calibrations.
Hoffman + Krippner
hoffmann-krippner.com.
Filed Under: Sensor Tips
