Floyd Bell’s stylish new Turbo Series piezoelectric alarms are twice as loud and half the size of industry counterparts. The tamper resistant front-mounting case with threaded attachment ring provides a watertight seal when used with our optional gasket. Our new, optional rotary volume control has twice the attenuation of industry counterparts.
Turbo series alarms are available in seven different tones (continuous, beep, warble, siren, whoop, staccato, and chime), two volume levels, and four terminations. Operating voltage ranges cover 5-30Vdc, 5-15Vdc, 9-48Vdc and 5-24Vac/dc. All Turbo models are UL recognized. Alarm size is approximately 1″ in diameter by 1″ tall.
Each alarm is tested three times before shipment.Turbo Series alarms are rugged and ready for the most challenging environments.
Turbo Series alarms are epoxy encapsulated and polarity protected. The solid-state electronics are housed in a 94 V-O flame retardant, heavy-duty thermoplastic enclosure with a stainless steel, corrosion-resistant sound diaphragm. NEMA type 4X environmental security when used with optional gasket.
These powerful, rugged alarms are the highest output, most water and vibration resistant sound devices of their kind in the world. Best of all, they are 100% made in the U.S.A.
Floyd Bell
floydbell.com
Filed Under: Safety systems + components
