The Fairchild Model 55 compact precision polymer pressure regulator is designed for high performance applications where space or weight may be limited or material compatibility concerns dictate the use of a polymer construction regulator. It features a separate control chamber that isolates the diaphragm from the main flow and a non-rising adjustment knob for controlled and simplified use.
Because of its small size, it works well in portable applications or those with tight weight or space constraints. Its polymer construction also resists contamination.
Stability of regulated pressure is maintained under varying flow conditions through the use of an aspirator tube which adjusts the supply valve in accordance with the flow velocity. The Model 55 pneumatic regulator features control sensitivity of 5-in. water column to deliver consistent and reliable precision accuracy to maintain your desired set point regardless of supply pressure changes or conditions. It will handle a 150 psi (10 bar) maximum supply pressure and offers four set point pressure ranges from 0-10 psi, (0-0.7 bar or 0-70 kPa) up to 2-100 psi (0.1-7 bar or 15-700 kPa).
Fairchild Industrial Products Co.
www.fairchildproducts.com
Filed Under: Hose • wraps + sleeves, Pneumatic equipment + components
