Miniature Quartz Force Sensor
By Design World Staff | March 22, 2007
March 2007, Depew, NY, USA – PCB Piezotronics introduces Model 219A05 miniature charge output quartz force sensor, designed for industrial applications where space is at a premium. The sensor is ideal for obtaining an indirect measurement of injection molding cavity pressure by positioning the sensor behind an ejector pin. The high stiffness property of the sensor allows it to follow very fast transient events. They may also be used to measure short term, quasi-static processes. The removable cable allows for a choice of lengths and terminating connector type and facilitates easy field repair in the event a cable is damaged.
Full scale measurement ranges to 560 lb (2.5 kN) and compact size of 0.24 in. (6mm) diameter x 0.24 in. (6mm) height, allows the sensor to be used for other applications involving compression forces, such as push buttons, pin insertion on circuit boards, switches, and actuators.
For detailed product specifications, drawings, or additional information, visit www.pcb.com.
PCB Piezotronics, Inc.
3425 Walden Avenue
Depew, New York 14043-2495 USA
Tel: 800-828-8840 (toll-free)
Fax: 716-684-0987
24-hour SensorLine: 716-684-0001
E-mail: [email protected]
Web: www.pcb.com
:: Design World ::
Filed Under: Materials • advanced, SENSORS
