Schaumburg, IL — Misumi USA, Inc. has announced the recent expansion of its line of Washers for Stainless and Carbon Steel Compression Springs.
Compression Springs of all sizes are commonly used across a broad range of factory automation applications. Misumi‚’s ruggedly made Compression Spring Washers (Part No. SPGCC20-9-6) are available in two different types, with selection dependent on the application requirements. These include:
‚• Standard Type ‚– Available in 1045 Carbon Steel with Black Oxide Finish, 304 Stainless Steel, and four (4) new Resin types (Polyacetal in White and Black; and MC Nylon in Blue and Ivory). The lightweight yet rugged resin materials provide insulation and reduce the weight of the components.
‚• Tapped Type ‚– Features a threaded I.D. which facilitates adjustment to initial load. Two new Tapped Types include 2-Flat and Knurled styles in 1045 Carbon Steel with Black Oxide Finish and 304 Stainless Steel
Both the Standard and Tapped Washers feature an extended collar design which adds strength and reduces warpage or distortion during expansion and contraction.
Misumi‚’s comprehensive range of Round Wire Compression Springs is manufactured to precise dimensional tolerances. They are available in Spring Steel (ASTM A228) and 304 Stainless Steel-WPB. Product specifications, load calculations and technical data for Compression Springs and Washers are provided in the 2009 Misumi Catalog or online. Misumi also offers a wide range of Coil springs used in applications where a heavier load is required and are also common in a variety of Press and Die applications.
Misimi
www.misumiusa.com
Filed Under: Factory automation, Springs • wave springs • retaining rings • spring clips, Washers • spacers
