Misumi USA, Inc. announced the extension of its Linear Bushings “Pick2 FREE” special promotion through March 31st, 2012. The program is designed to highlight the company’s comprehensive selection of high quality, affordably priced Linear Bushings, which are available in a wide range of types and sizes.
Under the terms of the special promotion, machine and factory automation design engineers have an opportunity to order two Linear Bushing samples, absolutely free. This is a limited time offer and selection is limited to certain sizes.
MISUMI’s Linear Bushings are used in combination with Linear Shafts to enable smooth and precise linear motion in a host of industrial machinery and plant automation system designs, and in manufacturing and processing applications across many industries.
The firm’s Linear Bushings line-up includes a wide variety of styles in sizes ranging from 3 mm to 50 mm in diameter. Product styles include straight, standard flanged, mini-flanged, pilot flanged, and center flanged bushings. Also available are Linear Bushings with Pillow Blocks, Linear Ball Bushings, and bushings with clamp levers to allow clamping at a desired position. All versions are configurable to users’ application requirements and specifications relative to style, size, material, and lubrication options. And all are ruggedly constructed and rust protected for long service life.
MISUMI
http://www.misumiusa.com/LBoffer.aspx
Filed Under: Factory automation, Automation components, Bushings • plain (sleeve) bearings, Linear motion • slides, Mechanical, Motion control • motor controls
