MISUMI Showcases Linear Guides at ATX Canada
By Stacy Combest | May 17, 2013
MISUMI USA, Inc., a subsidiary of MISUMI Corporation, part of MISUMI Group, Inc. will display its extensive portfolio of Linear Guides at ATX Canada, Booth #939. Demonstrations will be available for machine and automation system design engineers seeking rugged and reliable linear motion solutions. In addition, shipping time for 95 percent of MISUMI Linear Guides is just six days or less.
MISUMI’s Linear Guide product line-up includes:
  • Interchangeable types in which the block and rail are sold separately and non-interchangeable types in which the block and rail are sold as a matched set.
  • Miniature Guides in a variety of styles designed for lighter loads. These have two rows of contacting steel balls in a 4-point raceway contact design.
  • Medium and Heavy Load styles designed for heavier loads, including Ultra- and Extra Super Heavy loads. These have four rows of contacting steel balls in a 2-point raceway contact design.
  • Low Temperature Black Chrome Plated types, featuring a 5 µm fluoropolymer layer chemically deposited as a black film on rails and blocks. This protective coating results in a durable finish that resists corrosion and is immune to cracking and flaking, even under repeated bending.
  • A wide range of standard and customized design options, including short blocks, long blocks, wide blocks, blocks with dowel holes, and dust-resistant versions for use where dust and machining chips pose a hazard to smooth operation.
  • Accessories, such as clamp, bolt and plate stoppers, height adjusting blocks, locking units and cross roller tables.
The Linear Guides utilize steel balls rolling on precisely ground raceways, with the balls being recirculated by plastic return caps. In selecting linear guides, design engineers must consider various specifications, such as allowable load and clearance requirements. Product experts will be available at the booth to provide engineering assistance using MISUMI’s easy-to-use online CAD Configurator.
To ensure proper installation, MISUMI’s Linear Guides feature a datum surface―a surface with a straight groove―on both the rail and the block to help users align the units correctly.
MISUMI USA
www.misumiusa.com
Linear Motion Tips
Tagged With: misumi
