Mitutoyo Ko-ga-me® compact, 3D CNC measuring system configures to almost any process
By Test and Measurement Editor | October 9, 2012
Mitutoyo America Corporation announces availability of the Ko-ga-me® measurement head – designed to bring full capability to applications where a compact, high-performance, 3D CNC, 2- or 3-axis measurement system would be ideal.
The Mitutoyo Ko-ga-me® is small-sized, requiring only a minimal envelope (17.3″ [440mm] x 16.1″ [410mm] x 4.7′ [120mm]) and weighing 17.6 lbs. (8kg).   This makes Ko-ga-me® agile and easy for a customer to mount – using either an available fixed base (wherein the work piece moves during measurement) or using a moving-axis mounting system of the customer’s own design.
Mitutoyo Ko-ga-me® measuring systems are available for horizontal or vertical installation and can be used in stand-alone applications or integrated into work cells.  Ko-ga-me® is ideal for inspection of large or small work pieces and offers a wide range of available measurement probes including touch-trigger, optical or constant contact probing.
The Mitutoyo Ko-ga-me® is available in 40mm, 80mm, and 120mm stroke models and offers a resolution of 0.02µm, a measuring accuracy from 1.5 x (3L/1000)µm, a maximum drive speed of 200mm/s (1 axis) and has a maximum acceleration of 0.4G (1 axis).  In addition the unit supports probes including: TP200+PH6, SP25+PH6M and QVP (QuickVision® Probe).
Mitutoyo Corporation is the world’s largest provider of measurement and inspection solutions offering the most complete selection of machines, sensors, systems and services with a line encompassing CMMs (Coordinate Measuring Machines), vision, form and finish measuring machines as well as precision tools and instruments, and metrology data management software.
www.mitutoyo.com
Test & Measurement Tips
Tagged With: Mitutoyo Ko-ga-me®
eBay
When to buy used test equipment
TRACO Power now sells cost-optimized 1-A POL converters with 6-to-36-V input range
eye diagram
Simpler debugging for Automotive Ethernet systems
E+H-Prosonic-flowmeter
Flowmeter for industrial water, feedwater, cooling water and condensate
