The MM Series pressure transducers offer custom Designed features with fast delivery. Their modular design allows you to construct a pressure sensor meeting application requirements with guaranteed fast delivery from stock to 2 weeks.
The MM Series is available in Gage, Absolute, Barometric, Vacuum, Compound and Differential styles, in ranges from 0 to 10″H2O through 0 to 5,000 psi. Multiple accuracies are available to 0.03% BSL. Simply choose your pressure type, range, units, accuracy, electrical output, process fitting and electrical termination from our on-line configurator and we’ll quickly deliver your custom designed transducer. Perfect for fluid and gas measurement, useful for controlling hydraulic systems, and measuring dry air flow.
www.omegadyne.com
Filed Under: Sensors (pressure), TEST & MEASUREMENT
