(Rancho Santa Margarity, CA) -MMD Components (Monitor & Quartztek) has introduced an ultra-miniature quartz crystal that has a wide frequency range of 16 MHz to 60 MHz and can operate in temperatures as low as -40ºC and as high as +85ºC.
Measuring only 2 x 2.5 millimeters, with a maximum profile of just 0.55 millimeters – the smallest available in production quantities – MMD's new X series crystals are hermetically sealed in a 4-pad ceramic package and delivered on tape and reel for easy pick and place. They can be used in any application where limited space is a key issue and a frequency reference is required, such as Bluetooth devices, PDAs, mobile phones and MP3 players.
The crystals have a frequency tolerance/stability rate as high as ±50 PPM/±100 PPM; are 100% RoHS compliant; and feature ruggedized construction for extreme vibration and shock applications, meeting MIL-STD-883 and MIL-STD-202 specifications.
www.mmdcomp.com
: Design World :
Filed Under: Electronics • electrical
