A major manufacturer of dredging systems needed a reliable coupling solution with a small footprint for use on a new dredging vessel platform. The system features a 1200 HP diesel engine that drives a complex, custom-designed, eight-pad gearbox with primary output to a two-speed clutch that drives the system’s main pump, as well as hydraulic pump pads to operate a crane and auxiliaries.
After a thorough application review, the Stromag engineering team designed a hybrid Periflex CR (PCR) shaft coupling to meet the challenging dredging rig application requirements. The modified PCR coupling used a rubber element from a similar Stromag model PCS coupling and a bolt-on adaptor hub with a splined bore. Extensive torsional vibration analysis (TVA) work was completed on this complex multi-stream system of 9 driven components as the coupling was sized to fit within the tight space constraints of the customer’s gearbox bell housing. The coupling’s flexible ring effectively absorbs torsional impacts.
Altra
www.stromag.com
Filed Under: Coupling Tips, Gears • gearheads • speed reducers
