LISLE, Ill ‚– Molex Incorporated (NASDAQ: MOLX and MOLXA) introduces the Stac64‚â„¢ connection system which provides single and multi-pocket PCB solutions to offer a diverse range of circuit sizes and greatly reduce time-to-market by completely eliminating custom tooling.
The new stackable connection system allows OEM and device manufacturers greater design flexibility to support both low-level signal requirements as well as power applications upwards of 30.0A. It also allows the manufacturers to use header assemblies as stand-alone components or to gang multiple headers together to support a large range of signal and power needs for devices and modules.
The standard product line, based on the 0.64mm (.025‚â€Â) terminal, includes 8-, 12-, 16- and 20-circuit connectors in both vertical and right-angle headers supporting low-level signal requirements. An additional 10-circuit ‚‘power pocket‚’ version, supporting power applications for 1.50 and 2.80mm (.059 and .110‚â€Â) terminal systems, is available in vertical and right- angle configurations.
The PCB alignment posts ensure all terminals are properly aligned into PCB through-holes during assembly and retain the header to the PCB during assembly and solder processing. In addition, PCB stand-offs molded into housings provide additional trace-routing real estate under the headers.
www.molex.com/link/stac64.html
