Moment of inertia: area or mass?
By Danielle Collins | May 6, 2016
Moment of inertia is an important parameter when sizing and selecting a linear system. But it’s critical to know which type of inertia—planar moment of inertia or mass moment of inertia—is given and how it affects the performance of the system.
Planar moment of inertia
Planar moment of inertia (also referred to as second moment of area, or area moment of inertia) defines how an area’s points are distributed with regard to an arbitrary plane and, therefore, its resistance to bending. Terminology varies, and sometimes overlaps, for planar moment and mass moment of inertia. If it’s unclear which type of moment is specified, just look at the units of the term. Planar moment of inertia is expressed as length to the fourth power (ft4, m4).
I = ∫∫ x2 dA
I = planar moment of inertia
x = distance to reference plane
dA = element of area
Second moment of area can be either planar or polar. Polar moment of inertia describes an object’s resistance to torque, or torsion. The equation is the same as planar moment of inertia, but the reference distance becomes the distance to an axis, rather than to a plane.
I = ∫∫ r2 dA
I = polar moment of inertia
r = distance to reference axis
The planar moment of inertia of a beam cross-section is an important factor in beam deflection calculations, and it is also used to calculate the stress caused by a moment on the beam. In linear systems, beam deflection models are used to determine the deflection of cantilevered axes in multi-axis systems. Unsupported shafts are also analyzed using beam deflection calculations.
Moment of Inertia
Cantilever beam with a concentrated load at the free end
Moment of Inertia
P = load
l = length of beam (distance to load)
E = modulus of elasticity
Mass moment of inertia
Mass moment of inertia (also referred to as second moment of mass, angular mass, or rotational inertia) specifies the torque needed to produce a desired angular acceleration about a rotational axis and depends on the distribution of the object’s mass (i.e. its shape) around the axis. It has the same relationship to angular acceleration that mass has to linear acceleration. Mass moment of inertia, like planar moment, is typically denoted “I,” but unlike planar moment, the units for mass moment of inertia are mass-distance squared (lbft2, kgm2).
The mass moment of inertia equation for a point mass is simply:
I = mr2
I = mass moment of inertia
m = point mass
r = distance to axis of rotation
For a rigid body, the mass moment of inertia is calculated by integrating the mass moment of each element of the body’s mass:
I = ∫ r2 dm
dm = element of mass
When sizing linear systems, the most important use for mass moment of inertia is probably in motor selection, where the ratio between the load inertia and the motor inertia is a critical performance factor.
Feature image credit: wikipedia.org
Linear Motion Tips
Filed Under: Linear Motion Tips, Motion control • motor controls
Danielle Collins
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
