Changes in process fluids indicated by pH or oxidation reduction potential (ORP, measured in mV), and temperature for more accurate control in water, chemical, electronics, food production, environmental and wastewater applications are easily monitored with Sensorex’s TX-3000 pH/mV transmitter. The transmitter’s dual output design provides an isolated, 0 or 4 – 20mA output for pH or ORP readings and one for temperature measurement displaying both parameters simultaneously on its backlit LCD screen. Two adjustable Hi/Lo relay contacts deliver results to automated process control systems. The unit has an extended pH measurement range of -2.00 to 16.00 and can be password protected for secure installations.
For more information about Sensorex’s TX-3000 pH/mV transmitter, click here.
Filed Under: Sensor Tips, Food + beverage, ELECTRONICS • ELECTRICAL
