Automation Products Group, Inc. (APG) introduces Tank Cloud Remote Monitoring – a cost-effective remote tank level monitoring system that enables users to monitor facilities and processes from anywhere with an internet connection, 24 hours a day, seven days a week. Using APG’s proprietary remote level sensors and modules, or any sensor with a 4-20mA output, Tank Cloud users can remotely monitor level, pressure, temperature, flow, pH and other process variables through an easy-to-use online interface.
Tank Cloud sensors and input modules connect to the user’s network via an Ethernet cable and transmit data via the user’s Internet connection, whether landline, cellular, radio or satellite. On APG’s intuitive Tank Cloud remote monitoring web portal, operators and managers have ready access to real-time and historical data, and can manage various alarms and set permission levels for various personnel. The system notifies all relevant workers of any alarms via email and text messaging.
To help users get the most from their Tank Cloud, APG has introduced three Tank Cloud-compatible sensing and display products. The robust MPX Series Magnetostrictive Level Sensor provides highly accurate and repeatable volume and level readings in harsh and hazardous applications that are prone to fouling or buildup. Designed to operate as a slave device, the MNU Series Ultrasonic Sensor can measure distance, level or volume from 4 in. to 40 ft. Lastly, the MND Modbus Network Display provides a local option to display readings from up to 10 sensors in the network; it can also be wired to a local Tank Cloud network, and can operate in master or sniffer mode.
Learn more about Tank Cloud Remote Monitoring.
www.apgsensors.com
Filed Under: Sensor Tips
