More Productivity1000 PLC I/O capabilities
By Leslie Langnau | September 25, 2018
AutomationDirect has added more AC, DC and analog I/O modules to increase the capabilities and versatility of the Productivity1000 micro-modular PLC.
The micro stackable P1000 PLC system provides communications, user-friendly programming, integrated data storage, and a full lineup of discrete, analog and specialty I/O modules in a super-compact size. The P1000 PLC system can be expanded with up to 8 I/O modules for a total of 128 discrete I/O points or 48 analog I/O channels.
Newly added direct current P1000 modules include higher density 16- and 15-pt VDC models, and 8- and 16-pt VAC/VDC input versions.
8-point 120-240V AC input and output modules have been added; new analog I/O includes RTD 4-channel input and combination 4-channel input, 2-channel output, 0-20 mA and 0-10 VDC modules.
Starting at $33.50, I/O modules are auto-discovered and easily added / removed using a single latch mechanism. There are no module placement restrictions and no power budget limitations. QR (Quick Response) codes are printed on each module for the latest specifications / wiring diagrams.
AutomationDirect
www.automationdirect.com/P1000
Filed Under: I/O modules
Tagged With: automationdirect
Io-link-Smartfield
IO-Link Smart Field I/O System from AutomationDirect
Beckhoff I/O terminal supports high-voltage measurement for renewable energy and EV technologies
Opto 22 releases groov RIO EMU distributed energy monitoring unit
Opto 22 releases new groov EPIC I/O modules for large-scale power monitoring, signal integration
