Mosaic is a modular and configurable Safety Controller capable of managing an array of safety functions ranging from a solitary machine to the operations of an entire plant. Mosaic can easily manage multiple safety devices including safety sensors and signals such as Light curtains, photocells, laser scanners, emergency stops, electromechanical switches, guard-lock safety door switches, magnetic switches, RFID switches as well as safety mats and edges, two-hands controls, and handgrip switches. The Mosaic allows for tamper-proof system configurations since all logic is configured through a graphic interface. Labor intensive wiring and setting up multiple devices is now a thing of the past with the Mosaic controller because using fewer electromechanical components means better Performance and therefore, a higher Safety Level. Thanks to the Mosaic ’s modular and expandable structure it is possible to adapt its I/O configuration and functionality to the demands of each application.
The Mosaic is DIN rail mountable according to EN 50022-35 standard, has a protection rating of IP 20 for housing and IP 2X for the terminal blocks and can operate in temperatures from -10°C to 55°C making it an ideal choice for a myriad of applications including machine guarding, material Handling machines, Robotics, AGV (Automatic Guided Vehicles), printing machines, Palletizing systems, Vertical lift storage system as well as rail dependent storage and retrieval equipment.
Norstat, Inc.
www.norstat.com
Filed Under: Safety systems + components
