    • On the Floor
MotiCont’s direct drive linear motors with integrated encoders
By Frank Tobe | September 16, 2014
New, patent-pending, SDLM-051 direct drive linear motors with built-in encoder from MotiCont eliminate backlash and provide users with high acceleration, high speed, high resolution, and long life. Available in several off-the-shelf models, these direct drive linear motors feature resolutions of 5.2 μm (0.000206 in.), 1.25 μm (0.000049 in), and sub micron resolution. Compact, only 2 in. (50.8 mm) in diameter and 3.75 in (95.3 mm) long, and with the linear optical quadrature encoder inside directly connected to the shaft for the greatest possible accuracy, these motors can be easily integrated into new and existing applications using threaded features on the front and rear faces of the motor, as well as each end of the shaft.
Monticont
The new SDLM-051 direct drive motors have a 1 in. (25.4 mm) stroke with a continuous force of 5.0 lbs (22.2 N) and a peak force of 15.8 lbs (70.2 N). Non-commutated, motors have zero-cogging, and the light weigh of the shaft allows for high acceleration/deceleration for higher thru-put, and direct coupling to the load increases accuracy and resolution. All SDLM-051 linear motors are available with a spring to retract the shaft to a home position in the event of a sudden shutdown, and they can be quickly customized to meet specific needs.
Typical SDLM-051 direct drive motor applications include: Automated assembly, component insertion, fluid dispensing, pick-and-place, robotics, wafer handling, sorting, valve and flow control, labeling, tension control, and laser machining in the processing, manufacturing, medical, inspection, metrology and other industries.
MotiCont
www.moticont.com
Filed Under: Motors (linear), Encoders • linear, MOTION CONTROL
Tagged With: moticont
  • Five trends in automation for the second half of 2026
  • Robot blowback in Korea and China growth slows
    • On the Floor
