Lin Engineering high-performance X-series motors deliver higher power density than ever before. The X5718 comes in a NEMA 23 (56.4 mm) frame size. High power density means that these motors can deliver more torque at a targeted speed than competitors’ motor of the same size. This is due to a unique motor design which provides exceptional torque to size ratio. The X-Series motors deliver:
- Higher dynamic torque
- Higher speed
- Smaller size
- Reduced weight
- Higher efficiency per watt for battery operated devices
- Reduced heat generation
- Higher efficiency at lower voltage
Lin Engineering offers more than just off-the-shelf solutions. For OEM type applications, they can customize the X-series motors to ensure optimal performance within the parameters of the specific application.
For more information, visit www.linengineering.com.
