FARMINGTON, CT — Mott Corporation will be displaying their new suite of Biopharmaceutical porous metal components and filters at Interphex 2009, March 17-19, 2009, at Jacob Javits Convention Center in New York City at Booth #3041.
Mott Corporation has developed a quick change sparger design that reduces the time and effort it takes to replace sparger elements in bioreactors and fermentors. The porous metal element can be purchased with a uniquely designed adapter that allows easy assembly to the mating sparger tip and easy removal for replacement after each batch. These spargers are durable, corrosion resistant and provide exceptional mass transfer efficiency. They have been designed to comply with ASME-BPE specifications, as well as cGMP guidelines.
Mott will also display their cartridge filters for vent, steam and gas line applications. These all-metal products provide superior strength, performance, and long life in biopharmaceutical processes. Mott porous metal performs in high temperatures, corrosive environments, and provides mechanical stability. Cartridges are available with 222 or 226 Code 7 connections and can be purchased separately or with the filter housing. O-rings are also available in a wide variety of materials.
Filed Under: Medical, Materials • advanced
