A full line of off-the-shelf products for face mounting components on a shaft, depending upon specific user design requirements, is available from Stafford Manufacturing Corp.
Stafford Mounting Shaft Collars include Flange Mounts with six mounting holes and a keyway plus the Accu-Clamp non-marring and perfectly square clamping feature for mounting a shaft, tube, or pipe to a flat surface or for attaching components to them. Additional solutions include Accu-Mount collars with precision locating hubs and predrilled and tapped holes, and conventional Face Mount Clamp collars with predrilled and tapped holes.
Providing non-marring clamping for various face mounting applications, Stafford Mounting Shaft Collars are available made from aluminum, steel, and stainless steel in 0.25 to 3-in. I.D. sizes, depending upon the part. The Accu-Clamp Shaft Collars feature an integral clamp on one side while leaving the other flat and perpendicular within 0.001-in. TIR.
www.staffordmfg.com
Filed Under: Coupling Tips
