Move Small Masses Dynamically and With Precision
By Design World Staff | September 29, 2011
The MCL ironless linear motors position small masses with precision and maximum synchronization. The motors are easy to integrate into machines. Typical areas of application include assembly and handling technology as well as semiconductor and solar technology. The MCL product line has four sizes with graded lengths and a maximum force range of between 20 and 1,700 N. This enables an acceleration of up to 300 m/s² and a maximum speed of up to 1,200 m/min. Several primary components can be set up in a sequence or parallel to each other. The compact design enables different mounting planes for mounting primary and secondary parts for flexibility in construction design. Optionally, the linear motors also come with a Hall sensor unit to detect the position for the initial commutation.
Bosch Rexroth AG
www.boschrexroth.com
Filed Under: Factory automation, Motors (linear), Semiconductor manufacture, Material handling • converting, Motion control • motor controls
