    • Subscribe!
Moxa Converters Extend PROFIBUS Networks Over Fiber Optic Cable
By Editor | December 18, 2013
Driving innovation and extending its leadership in industrial networking technology, Moxa has introduced two new PROFIBUS-to-fiber converters that transparently bridge PROFIBUS to optical fiber, providing total isolation, protection against EMI/RFI interference, and freedom from equipment grounding problems.
moxa
Equally important, the two new converters help extend connections up to 2.5 miles on multi-mode fiber or up to 25 miles on single-mode fiber at data rates up to 12 Mbps — well beyond the speed and distance limitations of traditional twisted pair copper installations. An integrated Remote Fiber Diagnosis function eliminates the need for specialized test equipment and significantly shortens troubleshooting time in expansive installations by allowing one person to examine fiber connections for the overall topology from any individual converter.
The Moxa ICF-1280I has dual ports to build a redundant fiber ring with zero recovery time, while the Moxa ICF-1180I is a single port converter. Both models feature 2 KV isolation protection and dual power inputs to ensure that PROFIBUS devices perform uninterrupted. To avoid configuration errors and minimize manual configuration efforts of baudrate settings, both also incorporate auto baudrate detection. This feature enables fast, error-free configuration of the converters and significantly reduces system deployment time.
To prevent a single bus failure from affecting the entire PROFIBUS network, the converters feature a Bus Fail Safe that detects and recognizes noise signals. If the bus fails on one side, the noise signal will not propagate through the converter and affect additional bus segments. Also, the converter will automatically trigger an alarm notification to the field engineer on the location of the failure, allowing them to quickly locate the failed device.
Moxa
www.moxa.com
Filed Under: TECHNOLOGIES + PRODUCTS, Cables + cable management, Networks • connectivity • fieldbuses
Tagged With: Moxa
Nitra-iso-solenoid-valve-from-automation-direct
ISO 5599/1 pneumatic solenoid valves from AutomationDirect
person's fist holding a handful of igus cables
igus is adding 2,046 new macros to the EPLAN circuit diagram software
Product Image of the NTE2620
Acromag expands its line of ethernet remote I/O modules
Beckhoff’s EPX series EtherCAT I/Os provide intrinsic safety in IP67 form factors
    • Subscribe!
